J Alper
Site Sponsor
- Apr 30, 2021
- 2,015
- 1,749
its on e90 fuel.. intercooler not really needed im sure.I noticed on the turbo setup you are not running an intercooler. Does not running one hinder any performance? If it does is it very minimal?
It performs a little better when the Air is cool, with E90 when the air gets hot it will not detonate, but will loose power,I noticed on the turbo setup you are not running an intercooler. Does not running one hinder any performance? If it does is it very minimal?
Thank you for the explanation.It performs a little better when the Air is cool, with E90 when the air gets hot it will not detonate, but will loose power,
#1 thats what i figured LOLran it twice on 26lbs was undrivable, at 15lbs it made 160 on the air temp with 55 degrees ambient, at 80 degrees ambient it was around 180, after 5 passes down the drags at Dumont it was around 220 degrees, at 220-240 degrees if felt more like 5lbs of boost,
After all the bugs worked out, Next step is a Dry Sump and later a water to Air Cooler, like the Holley with the Tick Cooler,
Density suffers for sure, but the associated quantities of E90 no doubt evap-o-cool those temps down to reasonable.V8's dont get me excited, but this one looks Sick!!! very nice packaging, super tight! super clean!!
the only saving grace of "not" having an intercooler is that this thing will make so much power you couldn't keep your foot in it long enough to sustain 26psi
26psi is making a super ton of heat and i am surprised there isnt an intercooler but then reread above for explanation ^^^^
intake temps go up exponentially with boost, im guessing air temps at that boost level are in the 300F degrees at that pressure, ouch
but if it works... then run it cause it looks awesome
I would say that air filter cant flow anywhere near what that motor is going to need
maybe holley low or mid ram with a shearer fab air to water combo on top?After all the bugs worked out, Next step is a Dry Sump and later a water to Air Cooler, like the Holley with the Tick Cooler,
yes, but unfortunately the fuel doesn't mix with air super hot air until 2" before it enters the combustion chamber. not sure how fast 300 degrees can go down in 2" with the quantity of hot air that's moving around in there?Density suffers for sure, but the associated quantities of E90 no doubt evap-o-cool those temps down to reasonable.
It's not cooling the air by contact like an intercooler, but evaporation. DI engines cool the intake charge and there's 0" before it enters the combustion chamber... :biggrin:yes, but unfortunately the fuel doesn't mix with air super hot air until 2" before it enters the combustion chamber. not sure how fast 300 degrees can go down in 2" with the quantity of hot air that's moving around in there?
