John@Outfront
Forum Moderator
- Apr 30, 2021
- 1,699
- 2,549
That will do it!!!That’s my setup. Holley lo ram with a shearer 1800hp intercooler. Works great!
same here, but mines a hi ram. low ram for ls3 heads wasnt out when i bought everything. im running the monster ls3 heads from frankenstein.That’s my setup. Holley lo ram with a shearer 1800hp intercooler. Works great!
Yep I bought it right when they came out. Then they went on like a 6 month back ordersame here, but mines a hi ram. low ram for ls3 heads wasnt out when i bought everything. im running the monster ls3 heads from frankenstein.
That fuel eventually makes it into the combustion chamber though. It will still continue to evaporate (and by effect, cool) the combustion chamber.So that is a great article, my thoughts
#1 it clearly stated that DI is far superior to charge cooling than port injection. the motor we are talking about in this thread doesnt have the advantages of DI where the cool fuel is injected directly into the chamber. PFI mixes the two before it enters and actually raises the fuel temp by the hot air and is less advantages. you see the results as the DI motor exhibited less knock tendencies compared to the PFI. i agree DI has an advantage as it doesnt mix with the hot air first. The DI system also runs at insane fuel pressures so the evaporation process is enhanced over PFI this is more the reason for better cooling than the "0" inches from combustion chamber argument
#2 that test is brilliant and even more brings home the reason that you talking about DI being better cause it is "0" inches away shows the advantage of DI.......
#3 clearly the hotter the charge (and 26psi is super hot) has a significant effect on charge cooling (with any fuel)
Agreed and enjoy the discussion as wellThat fuel eventually makes it into the combustion chamber though. It will still continue to evaporate (and by effect, cool) the combustion chamber.
Intercooler is definitely better. No argument there, but as you most definitely know, Corn lets you get away with stupid chit where mechanical failure of components is far more concerning than detonation.
You’ve done far more in engine tuning than I have, just having fun discussing finer points. :biggrin:
Mustang Dyno 865HP at the wheels on BFG 37'', weddle-S5D, Then the tires broke free, really needed the Hub Dyno to see the numbers. It now has a AEM Boost Dial into the Holley, its about 1.6psi per setting, full tilt at 11 on the knob is now about 18lbsWow. Btw what was the hp at 26 psi?
which one is which? and what are you "seeing"?When choosing a crank for boost, you can see the difference in a Dart Billet Pro Boost, compared to a Lunati Sig Series
The hole when you can see the bottom is the lunati, that hole is almost 1'' round, so it gets really close to the drilled oil hole, the other as cast is the Dart, hole is around 1/2 round, I think the smaller holes is smarter, but had to add weight to the crank for balance,which one is which? and what are you "seeing"?
got it and agreedThe hole when you can see the bottom is the lunati, that hole is almost 1'' round, so it gets really close to the drilled oil hole, the other as cast is the Dart, hole is around 1/2 round, I think the smaller holes is smarter, but had to add weight to the crank for balance,
