Bobalos
- 5,299
would you reduce that down to something I can understand??? LOLIm kinda suprised; thought it would read 2/8 instead of 1/4
Now pretend this is a double lemon pie………2/8 would not work here because then the orange piece would be two pieces and you would have to share the other, when you have a true 1/4 piece it’s all yours! Is that easier to understand? Also in this example a mechanic could use the crescent wrench as a spoon as long as it was set to zerowould you reduce that down to something I can understand??? LOL
And actually, the wrench handle would be used as a pie server. Again, making it muli-usesAlso in this example a mechanic could use the crescent wrench as a spoon as long as it was set to zero
Ive found that this works the best as a spoon/fork.........Now pretend this is a double lemon pie………2/8 would not work here because then the orange piece would be two pieces and you would have to share the other, when you have a true 1/4 piece it’s all yours! Is that easier to understand? Also in this example a mechanic could use the crescent wrench as a spoon as long as it was set to zero
It's too early for me today!"through" or "threw"???? which UOM are you working with??? LOL
And I STILL grab the wrong one............ LOL.I have some adjustables that have these graduations on them. Mine are pretty good quality. Sometimes I would use them to check the size of something that I was unsure to save myself some guess work so I could grab the right size wrench or socket.
