Have you ever.....
Bobalos
Have you ever been using a chinese-ium  crescent hammer and wondered, "gee... I wonder to the nearest 1/4", what size this is" ??? In both sae and metric... lmfao
Unless you moved it a little when you flipped it over...5/16 is 9mm??
would you reduce that down to something I can understand???  LOL
Now pretend this is a double lemon pie………2/8 would not work here because then the orange piece would be two pieces and you would have to share the other,  when you have a true 1/4 piece it’s all yours!  Is that easier to understand?  Also in this example a mechanic could use the crescent wrench as a spoon as long as it was set to zero
Ive found that this works the best as a spoon/fork.........
Hmmmmmmmmmmmmmmmmmm.  inquiring minds want to know.....  LOL.
So, if you choose to use an adjustable wrench, wouldn't you just adjust to fit and not set or look at the number or fraction on it?
They really through a "wrench" in the system with the added information. Someone has a sense of humor.
"through" or "threw"????  which UOM are you working with???  LOL
I have some adjustables that have these graduations on them. Mine are pretty good quality. Sometimes I would use them to check the size of something that I was unsure to save myself some guess work so I could grab the right size wrench or socket.
And I STILL grab the wrong one............  LOL.
I retired several years ago from the hardware industry after 40 years. You would be surprised how many people would come in
looking for nuts or bolts and would say I need help with a 7/16 inch nut.  So I would grab a 7/16” nut and show it to them. They would
say that’s wrong, that’s way too big. So then I would show them a 1/4” nut and they would sometimes laugh or reply I
don’t understand why it’s called a 1/4” when I’m using a 7/16” wrench.   I thought it was fun educating the public on a nut and bolt.
:classic_biggrin:
