I've had it both ways, and I'll say (even though it goes against you wanting my trailer
) with a high-end car you'd want to put away nightly/in bad weather paddles on, no question. If it's just for the trips/to from, not putting away mid-trip it's generally no big deal. There are exceptions, like my last stacker. It was a "ramp style" stacker, and the SxS went up top, the sand car under it. The paddles needed to go up on the loft in front of the ramp-lift. So it became a sort of pain for order-of-operations. It was easiest to change the tires on the sand car first, then use the ramp to bring them up (being extra-lazy I'd just set them on the edge of the ramp, then winch it up so it was a flat-roll to the loft). The problem was, either you needed the RZR on the ramp first and had to sneak the paddles around it, or you needed to park the rail far enough away to drive the RZR onto the ramp after the paddles were up, but that meant backing the rail up in soft sand on load tires (aka a no-go) or a super-long winch pull. Definitely "first world problems" but if I ever do a stacker again, everything will drive in it on the sand tires, period. If I ever have another high-buck sand rail, it will have a trailer it drives in on the sand tires so it can be put away in inclement weather.
-TJ
PS- I'm a terrible salesman
