Hey guys, those with super chargers what are your air intake temps running. I am fighting temps in my car. When I had my new Gtu was always running 148 and higher never could get them lower with a 440/Whipple 4.0 My new car runs the same temps on a 402 with a Maggie 2.6l. while duning my temps are getting up there. sometimes the last part of the run I am 170 and then the engine removes timing. below 140 the engine is stronger than my 440/4.0. I have a separate heat exchanger in front of my Radiator and have a pump running 32 gal per min. I am going to add a tank and up the line size going into the pump. Tank should hold a gal or more. Line size going to the pump will increase to 1" . Heat exchanger and lines going to the blower are 3/4" right now. who tracks there temps and what are they.? I hear people running 100 degrees and have no clue how they are that low. My intake sensor is in the super charger right by the brick so It is true temp. Not a sensor in the intake tube before the TB.
