Fullthrottleguy
Site Sponsor
- 1,486
Stock LS and basically anything 550HP or under no reason to spend crazy money on an A1000Replace Bosch -6 fuel system with Aeromotive -8 (A1000, pre/post filter, regulator and all new -8 fittings/hose)
If you have a Bosch 044 and decent Pre and Post filters, a regulator that will give you 58PSI and -6 line you will have issues
500HP from HONDA via 500HP from and LS uses the same Lbs/hr of fuel to get there - in fact a Turbo car vs NA has greater fuel needs (efficiency)
If you did not starve the Honda - you will not starve the LS
If the fuel system is old - change the lines (keep the hose ends) and change the Filter elements out.
If the Bosch pump is old buy an AEM-400 - that pump is good for the same HP as the A1000 and costs $150 (but from a verified dealer - there are counterfiets out there)
It you are pulling tank and want to upgrade to a -10 outlet and use a shutoff valve and Pre Filer -10 in and out - its not a bad idea
If you were not running a fuel regulator with a return previously - you will need one - thats a good place to spend a few $$ and buy and aeromotive 13129 regulator inexpensive and good for over 650HP
If you decide to go Bigger make sure you go -10 in not -8 because any pump you use that is higher Lbs/hr than say the AEM will need -10
The brushless pumps are a waste of money unless you want to make over 1000-1200 Crank HP as you will need a motor controller so they don't overheat with just 500HP or less until you go Big 1000HP TT and you will not get good regulation with a large regulator that wants to flow for 1000+ plus on 500HP engine, I have "fixed" lots of those problems on people that put "race car parts" on mild cars - its easy to spend $2500 on that type of fuel system and it will not give you 1 more HP. I did lots of Fuel system upgrade with aero Brushless stuff for E85 and doing it US parts and good E85 compatible line - the parts are easily $2500 if you want fittings and lines that e85 won't eat ( Earls or XRP) in a year or two.
Spend that on a set of heads and cam and buy the AEM and get 100HP today ... FWIW
