J Alper
Site Sponsor
- Apr 30, 2021
- 2,048
- 1,774
We are a IMI dealer so couple of things we have done over the years
101, this is the standard starter for 4 cylinder Vdub for 2D and type-1 bellhousing
101-N for offroad for the 2D S4 bellhousing
104 for Bus trans or using a 2D clutch in a S4D bellhousing This has a .500 longer reach than a standard 101
Full size bellhousing is a 140
Ok
Now lets add some options MD models so if you do a IMI-101NMR this is a larger tooth to speed up the cranking speed, stands for Mazda Rotary
Very custom would be a IMI-101HD 101 is about a 1KW, 101N is about 1.4KW and the HD would be a 2KW, it is a Deisel starter with a adapter for chevy or VW,
so HD will get you to a 2KW, and the MR will get a bigger gear
most 101 spin around 300 RPM the MR will get up to 500-600 RPM,
attached is the catalog,
they make up to a 5kw starter insane!!!!!!!
IMI Catalog2016.PM6 (hitorque.com)
Ok
