I found starting with installing a Victron smart shunt is by far the best way to go (10 mins to install)
it is a gauge to see exactly what your system is using and putting into the system
It shows every light switch you turn on instantly, and has a history of voltage Amps everything and uses Bluetooth
it makes it so easy to diagnose things I found my fridge was turning off in the middle of the night
(start up capacitor was going out.)
Once you know what your usage is , then build your system
with my 36 Phaeton with residential fridge I use 250 watt about per hour while camping.
Went from (6) 6 volt Trojans to (2) 260 ah lipos
More then enough battery power to run 24 hours no charging
but we need more solar (currently 750 watt) to charge fast enough on the short winter days summers no problem
With just solar I can run with out genset for 2 days.
to get through a weekend I would still need to use the genset about 6 hours total over the weekend to keep up.
Aanother a cheaper and easier solution would be build in a Honda 2000 in trailer (on the tongue in sound proof box)and run it for a few hours at dinner.
Two lipo batteries li time 230 ah with cold charging shut off with coupon $1000 (6 Trojans would be $750)
https://www.amazon.com/Litime-LiFePO4-Battery-Lithium-Phosphate/dp/B0BYH8J176
Renogy 60 amp Dc to Dc charger $179
https://www.amazon.com/Renogy-60A-Battery-Multi-Stage-Charging/dp/B07Z4GSYC2
Victron 500 amp Smart shunt $120
https://www.amazon.com/Victron-SmartShunt-500AMP-Bluetooth-Battery/dp/B0856PHNLX?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=A3EYYKYFTRLN23
them went in changed charging profile to lipo Really easy to install
