Jammer75
- 377
Car (Subaru ej20 7-8 lbs) built originally in 2008 with single fan(built into wing about 30°-40° angle(intercooler in front of fan)). When it kicks on it draws a good amount of hot air through it. Radiator has been checked and cleaned. Out front restrictor installed. Temps below 60° car runs 210° (fan kicks on at 180°), 80° Car runs 210° Will see 220° occasionally but usually giving it a rest on the throttle at that point. Temps over 85° car will run 210° if kept in the right speed of airflow, around 3 gear 1/3 throttle, otherwise temps more consistently in the 230°+ range and can slow down and cruise and it comes back down to 210° . Everyone says go to dual fan and I think that would help as I want something that can dune hard for a while. I think I’ll need to cut open my radiator housing a little to accept a dual fan as well to optimize the air it can pull through it.
Question can I just wire the dual fan in to the same plug that was for the single fan? As far as I can tell, not sure which order, it runs to the computer, a relay and probably through one of the fuses on the fuse block.
thanks for any input.
