- Thread starter
- #21
I've been running the lipos with the Magnum for a season already, so my charge profiles are all good I think. There's lots of info on setting up the Victron correctly, so that should be good. On my Magnum, I have a profile setup to charge to 100% and another to charge to something like 60% for storage. I will try to do the same with the Victron.we will need that much power. Great solar controller. when you put the panels up there make sure they are not in any area that gets shade. if even part of the panel is shaded it won't produce power. I have 1000w with the same controller. I run 560 mah lipos with two magum inverters. You will have to get into the settings of the Magum. make sure you float charge is set to 14.4 volts and you should be setup great
