Diesels will always turn the oil black in short time from the sootI have a 2011 Dually, 6.7 Ford
I only use it to tow the ToyHauler, I Change the oil Every 6 months or Once a Year, This equals about 3,000-5000 I Use the Ford Filters From the Dealer, and AmsOil, Oil was super black, thinking about doing it 3 times a year about every 2000 miles,
The Trailer is 47-Foot around 21,000 Pounds, Have a sensor go out but no major engine failure, I purchased the truck with 90,000 miles and now has 130,000 miles.
That, and cam phasers on variable valve timing engines (almost every modern engine) clog super easily.I personally change every 5k miles or yearly in all of my vehicles, synthetic or not. The diesels also get fuel filters every 10k/2 years. I pushed the moho oil out to two years this last time because it got so little miles on it in 2020 and it holds 29 quarts of oil.
DI gasoline engines with cam chains are prone to chain stretch due to soot contamination in the oil which gets trapped in between the chain pins and links and over time wollers out the links. Going 7,500-10,000 miles between oil changes will cause you frustrations down the road on those.
I had to swap an oil filter (bought the wrong one) from an oil change I did a little over a week prior from my CTD Yodge. Midnight black...I have a 2011 Dually, 6.7 Ford
