Chingon619
- May 6, 2021
- 1,084
- 941
Ok fellas, need some help here. I can't figure this one out. I'm adding bypasses to my new car but using old arms from another car. Turned out, the builder moved the upper shock mount location leaving me looking for a new position and I buggered them all up. Found a home for single shock location (got me through the season) and now need the 2nd location for the bypass. The new frame has a beautiful bulkhead with the bypass about an 1.5" higher and about 4.5" space between the two shocks.
Do I need to place the bottom mounts side by side? Makes sense as the bypass ext to compressed is a little more than an inch longer than coilover. Problem I'm having is, there's no space!
why is this racking my brain? I've done a lot by myself but building new arms is out of the question. Check it out and would love to see others bottom shock mounts and how they are done. Check out my pic and any advice is welcomed.
Stuff I'm wondering, if I moved them more inward where there is more space, do I just back off the collars at the top of the shock? Isn't this collapsing my shock more at ride height? I don't know, but I've gotta figure something out.
