Jason I think thats the C kit?- I did an Aviaid 2 years ago the "d" kit was right at $3600 for everything - thats the Billet pan vs the fab pan - fab pan is $3K
and finding room for that Huge tank is always fun ....
its nice to use a 5 stage with TT cars to scavege off the Turbos
I have to agree other than worrying about tossing the belt due to sand - your oil supply is bullet proof - are you running a low OIL pressure shut off switch? I have done those on every Dry sump for fear of sand pulling the belt off - seems like a must
We are a Dealer for them, i dont really do there numbered kit we have a part number list that we use, The standard sheet metal pan works good for most stroked motors, mine is a 4.250 so i had to do the 3'' sump pan, talking with john the owner, he feels that is the best pan for all the motors, but the pan is 3'' compared to 1.5'' and adds $60 to the build sheet, if you weld the fitting on the pan and deduct the fitting in the block that will save $50,
Most forget, that in that price on a new build, pan will cost $250, tray from mast is $80, baffle $200 and mellings pump $160 close to $800, so a dry sump should really be about 2K, difference,
Power, my motor is so snappy now, it feels like i did a cam change, not sure what the hp gain is, but on a normal sand car motor, due to the soft suspension, the we sump i would feel, has the crank in the oil all the time, these chassis are never flat like a street car, the are just whipping the oil all the time,
So far in two years i have not lost a belt, but we run the thick wall Jones Fab pulley guard, they stick up about .125 above the belt, and are .250 thick on each side, i hve seen one bolt break on a bigblock, but it was dry rotted, belt was 10 years old, so for $60 i would change the belt every other year,
I also run a oil light, this is a led tail light from the old school sand cars 1.5'' round, it is blinding when it come on,
also i have the Holley HP setup to pull back timing under low oil pressure, enough timing it will stall the motor, not sure if that is the right way to set the oil pressure sensor, but if not i think you should start a post on holley tips and tricks like the S4 gauge setup,
