JM PRO
- 211
I had an o-ring on the pick up tube fail and caused me to lose oil pressure on a J35 engine
Wash down the oil with gas maybe?I don’t see how this would affect your oil pressure, thinking you still have some unresolved issue. Sucks to see that cylinder on a new engine
I don't either, but I'm grabbing at straws now.I don’t see how this would affect your oil pressure, thinking you still have some unresolved issue. Sucks to see that cylinder on a new engine
Ya, I'm going to take the block to a shop and see what my best option is.He's starting over, one way or the other...
I'm thinking of trying to pull them out and putting them in another block or seeing what it would take to re-sleeve the cylinder (if that's even a reasonable option)Hopefully you can get the block guards out.
I'll double check this. I installed a new oring when I put it all together... but that doesn't mean it didn't fail. My only thought left is that the brand new oil pump I put on it is bad.I had an o-ring on the pick up tube fail and caused me to lose oil pressure on a J35 engine
That is correctYep get another block and maybe your piston isn’t damaged as it’s on the side but if the rings don’t spin perfectly then the ring lands were damaged too. C clips never fall out when installed properly.
Taking the block down the get it fixed. Never found the oil pressure problem. Everything looks good as far as I can tell. I might try a different oil pump when I reassemble the engine.Any Updates?
I have another engine I could throw on it, but my season usually ends in March anyways. With Gas prices and everything going up, we decided this was our sign to just end the season. The wife owns 51% of the votes in my house too, lol.Buy a junkyard engine and turn the boost down. Finish the season out..
I gave the injectors away to a friend. The effort to swap over for the remainder of the season isn't worth it at this point.You could always swap the block and the injectors over. Turn the boost way down, so you dont have to miss the end of the season. Just a thought
