LtPyro
- May 6, 2021
- 182
- 69
So in a nutshell, I built up a Honda j35 block and put it in my car. I test started the engine and everything seemed fine, so i decided to take it to the dyno to have it tuned. On the first pass the car lost oil pressure and can't seem to get the pressure above about 15psi even while running the rpms up. Mine, and the guys at the shop, first thought was a bearing had spun. I pulled the oil pan off and check all the rod bearings and the main bearings, all of which look perfect. Other than that what other possibilities am I looking at for loss of oil pressure?
I installed a new oil pump when I built up the block. So that is a possibility, but I would like to believe its not. What else can I check before tearing the engine down to check the oil pump?
