To clarify, your using (2) 200ah in parallel?(2) 200ah chins from amazon
make sure to get a 200amp bms though
tons in our group for a few years now and no failures
game changer
Plus (2) Solar panels with 380Watts should help.I went back Old School on my new 5th wheel.... tired of dealing with 6-volts and leaking, maintaining water levels, charging issues and short lifespan in my opinion.
Had (4) Interstate 27M-EFB Marine / RV 12V Deep Cycles installed. This new battery from Interstate is sealed (Wet / Enhanced Flooded) and acts like an AGM battery from what I'm told.
Zero maintenance and backed by a 2-year warranty....we will see.
27M-EFB battery | Interstate Batteries
To clarify, your using (2) 200ah batteries in(2) 200ah chins from amazon
game changer
One of my two deep cycle batteries is on its last leg. The lifepo batteries are basically twice as much power, and last much longerWhat's the advantage of LiFePO4 in a toyhauler?
Please let me know, my onan usually start pretty easy on the lead acid batteriesThere’s multiple people in the genesis Facebook group running two 100ah 100bms lithiums without issues starting the generator. I just got this same setup for mine so we will see how it goes!
They started my diesel genny for 2 years no problemTo clarify, your using (2) 200ah batteries in
Will one 200 ah battery start a generator?
Installed them Sunday morning and generator fired right up with no issues. There’s a small switch on my converter to switch from lead acid to lithium, and also changed the setting to lithium on the go power solar controller so it can fully charge the lithium batteries.Please let me know, my onan usually start pretty easy on the lead acid batteries
What brand of lithium batteries did you get? Did you use two 100 ah batteries in parallel? ThanksInstalled them Sunday morning and generator fired right up with no issues. There’s a small switch on my converter to switch from lead acid to lithium, and also changed the setting to lithium on the go power solar controller so it can fully charge the lithium batteries.
