JDMeister
Forum Moderator
- 28,777
Back In The Late 1980s and Early 1990s, I was a developer for Intel silicon.Today's technological revolution in space, ranging from long-term harsh-environment military space applications to commercial space telecommunications and internet access, is driving new trends in electronics components that can withstand varying levels of radiation.
Radiation-hardened and radiation-tolerant electronics are designed or upscreen-tested to withstand the effects of ionizing radiation such as gamma rays and cosmic rays, which can disrupt or damage electronic circuits. These components are crucial not only for orbital space, but also for space exploration, nuclear power plants, and particle accelerators.
Radiation-hardened and radiation-tolerant electronics typically share several different traits, such as shielding, redundance, rad-hard-by-design components, and testing and upscreening.
Shielding made from materials like lead, tungsten, or other heavy metals can protect sensitive components from radiation, while redundant systems and circuits often are built into radiation-hardened electronics to ensure continued operation even if parts of the system suffer disruption or damage from radiation.
Some space applications -- especially those in high-Earth orbits for long-duration military missions, require components that are specially manufactured for heavy resistance to radiation-induced damage. This can involve different materials or designs compared to commercial-grade components, which can be time-consuming and very expensive to design. Rad-hard-by-design electronics typically are more expensive than commercial-grade components because of the specialized design, manufacturing, and materials involved.
Extensive testing under simulated radiation can help verify the performance and reliability not only of radiation-hardened electronics, but also of commercial-grade parts that can be designed into space systems.
When designing or specifying radiation-hardened or radiation-tolerant parts for space, systems designers must consider factors like total ionizing dose (TID), single-event effects (SEE), and displacement damage dose (DDD) to make electronic components that play a vital role in ensuring the reliability and functionality of electronic systems in harsh radiation environments.
Orbiting satellites for intelligence, surveillance, reconnaissance, and communications make up the bulk of today's space electronics market, with narrow but important slivers of the market going to long-term military missions, systems designed to operate through nuclear explosions, and for land-based nuclear power monitoring and control.
