JM PRO
- 178
I did not, it was tuned by Dardan. This issue was caused my be as I was greedy and asked to have the car tuned at 14PSI. What I think killed the block was that I had a loose fitting at the wastegate for a couple of trips the car was hitting 17.6lbs (Boost Cut) and finally had enough. Going to be ordering a closed deck block soon and will go back up to 14lbs.Did you tune this yourself?
Those look great and I am sure they would have!I used these block guards from Halferland. If i remember, they are roughly $450. Not as good as a closed deck but i think would have prevented what you experienced.
I haven't and I still use stock springs and retainers in my heads. I rarely hit the rev limiter at 6500 rpm. I am usually in the 5500 or less range. I am sure it would allow the engine to rpm higher but that is not something I want or need. I also don't think I am floating valves either and if I am I can't tell. I did rebuild the heads and had them decked and new seals including lapping the valves.Those look great and I am sure they would have!
Have you heard of any issues with the cylinder head valve train at higher HP levels? I have not but I do see that P2R sells different upgrades for the heads.
Before getting the block welded for close deck, look into Darden sleeves. Probably 3x the cost but much better product.I did not, it was tuned by Dardan. This issue was caused my be as I was greedy and asked to have the car tuned at 14PSI. What I think killed the block was that I had a loose fitting at the wastegate for a couple of trips the car was hitting 17.6lbs (Boost Cut) and finally had enough. Going to be ordering a closed deck block soon and will go back up to 14lbs.
I am going to run with the below. Claims to be good for up to 1000 HP.Before getting the block welded for close deck, look into Darden sleeves. Probably 3x the cost but much better product.
Lame..Put an LS in it and be done.
Sorry for your loss.
Yes it is I know.Lame..
LS won’t work well in the car. Issue is it is an SU ultralight and with too much toque thr car would probably rip apart. Plus I am way, way too deep into the HondaPut an LS in it and be done.
Negative. Just 15. I have to keep the 2D alive.So, 20 psi next go at at it?
They are not welded. They take an exact measurement of the block you send them, then they cnc the block and guard to be an exact match. Then it is pressed into the block. Here is a cutaway picture of one used on a B series motor.It doesn't look welded. Do they machine the case and then press in the aluminum stiffeners?
