Doing one right now,
Couple of things, the end of the hokey stick is pretty much where the S4 will end up, the cars i have done, i had to cut out the torsion tube, and brace under and above it,
Depending on the car, the one doing now i cut out all the trans brackets and used the motor mounts to reference the trans, did not want to move the motor due to wiring water lines ect. some will modify the trans mounts and move the motor, really up to you,
The other part of the work is removing all the interior so you can mount the new shifter, this can be a ton of work also.
Will also try to take some pics, but slammed till prez day,
