Has anyone successfully repaired a crack in their gas tank ? If so, what did you use ?
I have a crack at the base of my filler neck and was hoping to plastic weld it rather than drop $1100 on a new tank. Looking for proven suggestions before jus slapping some JB Weld on it.
It is located at the base of the filler, so it is not submersed or weight bearing. It is more of a issue when gas sloshes. Thanks
