Hi all you duners!! Hoping to get this motor fired up before vets. Hasn't started in over 10 years. I see a sticker that says 3PVF-AA5.
They want to go filter, fuel pump, filter. We were about to buy another Bosch F5021, but then wanted to check specs to confirm it can be used on the pressurized side of the pump.
The more i read the more mixed reviews i got about which filters work best upstream vs downstream.
Figured asked on GD and get a solid answer. We have the one bosch F5021 and can use that either upstream or downstream.
Will (2) Bosch filters become too restrictive? What 2nd filter should we get, if any?
Also where do most duners buy FPS fittings?
Any advice on preparing the motor for its first cold start is appreciated too. We drained the coolant and oil. Im happy to lube the cylinder walls however you guys recommend.
