John@Outfront
Forum Moderator
- Apr 30, 2021
- 1,525
- 2,159
Has anyone ever thought about doing front turning brakes or played around with the idea?
What do you think?
What do you think?
Are you talking about the "hoon handle"? I used to be coo like you but I was only doing Class 1 stuff. The teams new Mason Motorsports 6100 truck has one and it locks up both rear brakes. Haven't been in the truck myself but was told if the truck gets out of shape you grab the handle and it'll straighten the truck right out.I could be wrong as it is not the truck I work on (I'm barely cool enough to only work on the Pro4 truck), but I think RJ Anderson's Pro2 truck has a dual brake pedal type design that allows him to bias front brake left and right.
We don't use this on the Pro4 truck since the front diff he uses is essentially a spool.
Obviously vastly different vehicles and weight transfers, may not work in a mid/rear engine buggy with all the weight at the rear.
I usually try to have someone t-bone me with a semi truck or a large farm tractor on the right when I’m trying to turn left and vis-à-versa when I’m turning rightI have plenty of ideas how to turn faster.
How about reducing the timing on the drivers side of the engine when you want to turn left?
If you want to turn hard left, have your shock pressure on the right side increase by 200 psi.
How about dynamic tire size, turning direction tire shrinks by 30%.
Employing older technology, use a sand rudder.
Follow me for other breaking Engineering theories.
It's got one of those too, but he doesn't use it much. Rear is spooled on both trucks, so no independent rear turning brake.Are you talking about the "hoon handle"? I used to be coo like you but I was only doing Class 1 stuff. The teams new Mason Motorsports 6100 truck has one and it locks up both rear brakes. Haven't been in the truck myself but was told if the truck gets out of shape you grab the handle and it'll straighten the truck right out.
I’m thinking have 2 levers, the vertical ones that do 2 wheels, left one for rears, right one for fronts. With 4 levers, I’d feel like inspector gadget.some of you should do stand up comedy, (i would go)
my wifes car has lane assist that applies both brakes on one side to "pull" you back in the lane. it works pretty nice and yes that is applying the brakes on the turning wheel.
i dont think locking up a single turning wheel on the inside would be a big deal.
so none of you think it could would to any advantage (in the sand) i may have to just try it. my first idea would be to have a second turning brake right along side my normal brake, just with a shorter handle. if i want both wheels on one side to brake i would effectively grab both handles , if not then just grab the regular rear only
