Jtmoney714
- May 6, 2021
- 991
- 900
Intake air temps.IATS?
I've seen some cars with their filters all sucked in, which made me think the filters were definitely too small... My filters still look look good.
Blowing out a paper air filter with compressed air blows holes in the filter media. I only blow out air filters if there's an inner and outer filter (2 stage filtration) usually cylindrical type. Basic maintenance goes like this; only clean outer filter with compressed air no more than 3-4 times before replacing. Never clean inner filter and replace at same time as replacing outer filter. Cotton/gauze filters do not protect against fine contaminates. Paper filters provide the best filtration but need to be big enough and need to be replaced often.I went to running the R2C dry filters. They actually filter better than the oil a gauze style and when they're dirty you just blow them out from the inside.
http://www.r2cperformance.com/
Hence the "...get a second set and swap them out mid dune trip..." in my earlier post.Doing their job yes but I would think at some point becoming restrictive. The outerwear isn't really designed to be coated in oil and then covered in dust like a filter.
That was my theory... well it’s good to know that it isn’t anything to worry about. Not sure if my BOV is adjustable or not. I can hear it venting when I lift, but who knows if some is through the filters.If your blow off valve(s) aren’t sized properly than at every chop of the throttle some forced air will push back through the turbo. It will coat the pre filter with the oil residue from the filter.
Even some properly sized yet not sprung correctly blow off valves will do this.
Hell on my sleds I prefer it so I can blow the snow off the pre filter to get good air with just a quick chop of the throttle..
Nothing really to worry about.
agree with this.I think you are just using too much oil on them. I use the red oil from K&N so I can see where it has been sprayed. Then I don’t install the outerware until I get to the dunes or on the way. I never have enough oil to blot it off the next day.
I ran them for a bit. You have to replace them every season minimum or dust gets in. I was getting dust migration after a season on their largest 3" inlet filter with a 280whp engine. I switched to Donaldson cansiters, knock the primary filter out every other trip, and haven't had any color change on the backup media in 2 seasons now. Replacement media is like $30. Not enough flow through the unit I have for this motor (might not even work with 2), but I'd watch those R2Cs carefully or more than just your screen name will be dusty. :biggrin:I went to running the R2C dry filters. They actually filter better than the oil a gauze style and when they're dirty you just blow them out from the inside.
Does it gobble like a turkey, or give a nice solid "CHUFF"? If you hear gobbling turkey sounds, it's either too small or not adjusted correctly. If it's recirculating back into the intake, get a Mity Vac and adjust it so it cracks open around 17-20in-Hg. If open to atmosphere, make sure there are filters on them and tighten until they DON'T open at normal idle.That was my theory... well it’s good to know that it isn’t anything to worry about. Not sure if my BOV is adjustable or not. I can hear it venting when I lift, but who knows if some is through the filters.
Thanks For the heads up! Will definitely be watching more closely than I previously assumed. It is one of the biggest filters they have so hopefully that gets me a bit more life.I ran them for a bit. You have to replace them every season minimum or dust gets in. I was getting dust migration after a season on their largest 3" inlet filter with a 280whp engine. I switched to Donaldson cansiters, knock the primary filter out every other trip, and haven't had any color change on the backup media in 2 seasons now. Replacement media is like $30. Not enough flow through the unit I have for this motor (might not even work with 2), but I'd watch those R2Cs carefully or more than just your screen name will be dusty. :biggrin:
This is another issue (BOV) and @Rockwood a great way to explain the sound of Turbo surge. I doubt that will make any difference in the condition of your filters, but it will definitely make your car more responsive off and on the gas, and the turbos live longer by fixing it. I need to dig up the pics of twisted turbo shafts from just that issue....Does it gobble like a turkey, or give a nice solid "CHUFF"? If you hear gobbling turkey sounds, it's either too small or not adjusted correctly. If it's recirculating back into the intake, get a Mity Vac and adjust it so it cracks open around 17-20in-Hg. If open to atmosphere, make sure there are filters on them and tighten until they DON'T open at normal idle.
Filters? Even tightened so they don't open at idle, a healthy motor will still pull near-perfect vacuum on decel at higher RPM, which will likely open all but the tightest (and probably non-functioning) BOV. No filters mean the BOV is sucking in whatever's around it, which is probably sand in Glamis. :biggrin:
I've seen chipped compressor wheels from it. Not good.This is another issue (BOV) and @Rockwood a great way to explain the sound of Turbo surge. I doubt that will make any difference in the condition of your filters, but it will definitely make your car more responsive off and on the gas, and the turbos live longer by fixing it. I need to dig up the pics of twisted turbo shafts from just that issue....
Thats amazing ... They really think thats good. So painful. It's almost as badd as when I hear guys bouncing off the rev limiter constantly not realizing they are floating the valves and worse hammering the rod bearings .. well they might realize a problem soon enough1 hour ago, Rockwood said:
Bunch of these have the gobbling turkey.
Mine does more of a woosh sound when I let off. Not the cool Turkey gobler... so I assume it’s working okay.I ran them for a bit. You have to replace them every season minimum or dust gets in. I was getting dust migration after a season on their largest 3" inlet filter with a 280whp engine. I switched to Donaldson cansiters, knock the primary filter out every other trip, and haven't had any color change on the backup media in 2 seasons now. Replacement media is like $30. Not enough flow through the unit I have for this motor (might not even work with 2), but I'd watch those R2Cs carefully or more than just your screen name will be dusty. :biggrin:
Woosh is good.Mine does more of a woosh sound when I let off. Not the cool Turkey gobler... so I assume it’s working okay.
Hold my beer .... I saw this on TikTok it must be easyI can't imagine these filters are too small for this setup...
But mine also has filtration on top! That has to help LOLHold my beer .... I saw this on TikTok it must be easy
I cannot help it - I like doing the math rather than guessing or watching You Tube Video ...
So Here is the Math - - Lets see how it works out -
A properly oiled K&N air filter flows 6 CFM when perfectly clean and 4 cfm's per square inch (based on their spec) when dirty an Outerwear probably cuts this down a little
500HP requires approx 1000 CFM - you probably make 720HP (thats what Turnkey rates their TT LS2 at 9Lbs boost ..
So lets say 750Hp thats 1500 CFM - now granted you are not running at full HP all the time
but you need XX sq inches of Air cleaner - You can measure the Height and circumference of the two air cleaners and see how that works out ...
If your Air cleaner is 6" diameter (most are 5" at the bottom and 4" on top in that size ) and its 6" tall ... Lets assume its bigger
So use this formula and you will know the total surface area - since K&N measures CFM per square inch as "pleated" given the filter is actually much larger - due to the pleates
So 6" filter has a circumference of 18.84
so the total area of each filter is - 169.65" x 2 = 339 Sq Inch x 6 cfm = 2034 CFM PERFECTLY CLEAN and 1356 CFM dirty .....
So you decide - I would say your air filters are smaller than my calculations
But clean you are OK - dirty, not so much - so Take LRS's advice and put on new Air Filters after a day or two - or get bigger 8" air filters
I also believe the CBM's flow a little better from what read.
FWIW
It truly is very difficult to get all air to be displaced through a blow off when you are pushing quite a bit of pressure through the intake. Really the goal is to stop turbo stall. Most system slow the turbo but don’t stall them… this air goes back out the way it come.That was my theory... well it’s good to know that it isn’t anything to worry about. Not sure if my BOV is adjustable or not. I can hear it venting when I lift, but who knows if some is through the filters.
