I removed the wheels from the bottom, and then built a wooden base in the cabinet because even after removing the wheels the base of the fridge is still not flat, the hinge is still lower then the base of the fridge. It's no biggie, just a piece of 3/4 plywood. After the fridge is in position I made 2 "L" brackets that bolt to the rear of the fridge and to the floor of the cabinet. Then another "L" bracket on the top using the bolt holes in the fridge that are provided to move the hinge to the opposite side. That was already pretty damn solid, but I like to overdo chit, so I also put hooks in the floor of the cabinet and put a ratchet strap over the fridge and snugged it up. All of this is hidden by the trim that goes around the fridge. The new fridge is a few inches shorter, and 5 inches narrower. The top and bottom got a trim I made from aluminum sheet, and painted gloss black, blends so well with the new fridge it looks like it is part of it. The side got a strip of matching wood. (Actually it got a strip that does not quite match, so I'll replace it)
All in all, it's straight forward, nothing crazy, and definitely worth the time....
