ChasingSand
- 1,049
I got a weird situation happening and was hoping maybe someone has experienced this or dealt with this before.
When I had my car tuned, the tuner told me the coolant temp sensor was not working. He was able to bypass this and still tune the car.
Fast forward, I replaced the sensor and now the car is still having showing a coolant temp fault.
Here is where it gets weird, if I plug in my OEM ECU it reads just fine, showing ambient temp and will raise or lower as needed.
I have tested 3 different sensors and they all have the same fault. I sent the ECU to AEM and they replaced a burnt resistor and said everything is functional. Plugged it in today after the repair and same issue.
The doubt there is an issue with the Harness as it works fine with the Stock ECU, but am not 100% sure.
The sensor is putting out 5.10 volts cold and slowly rises as the temp warms up, but the car dies around the 170 degree mark as bumps up the injector pulse and floods the motor.
I called AEM and they are stumped as well.
Any Thoughts?
Any Thoughts?
