L.R.S.
- 2,655
Been a few since I've done a tech thread.
One of the simplest upgrades to do to any Duramax is the caterpillar engine oil filter. It's $20 for the adapter and they even have them on Amazon. Not only are the filters a lower micron then the factory GM filters they are alo half the cost. I buy in bulk, usualy 6 at a time, for around $20 shipped. When I did my 2006 LLY the filter adapter was just a double threaded nipple and I had to use a plumbers nipple tool for removal of the factory piece and install the new one. Seems like GM got smart and made the factory nipple on my 2014 LML a socket end for easy removal. The new adapter is installed with a 1/2" drive extention. It's a 5 minute upgrade if you do your own oil changes.
I also added the Caterpillar fuel filter adapter to my 06 LLY, my son's 06 LBZ and now my 14 LML. They have all been flawless but I know of one person that did have noting but problems and went back to stock after loosing prime for months. When I did my 06 LLY the adapter was around $150 but now you can get them on Amazon for $40. Read some bad reviews but the two I've installed have been good so far.
Stock GM 10 micron fuel filter is around $35 to $45. The Caterpillar filter is 2 micron and I get them in bulk for $19 each, shipped.
This pic is from my 06 LBZ. THe 1R- 0749 filter is too big for my mostly stock 2014 LML. I have to run the shorter Caterpillar 1R- 0750.
Next upgrade was the engine oil pan. I had 445k miles on my 06 LLY and never touched the engine oil pan. I always wanted to upgrade becuase I saw on Truck U or one of those shows that a factory GM Duramx oil pan hold almost a full qaurt of oil that cannot be drained. A buddy called me and said he had a brand new in the box AFE Duramx engine oil pan for $300. These retail for $450 so I bought it. Should have done a little research...
I did my usual YouTube University research and the swap looked really straight forward. The factory pan came off fairly easily.
This is exactly how much engine oil cannot be drained from a factory oil pan.
I swapped over the oil level sensor from the factory pan. A couple features of the AFE pan is the drain plug is magnetic (like we are used to on our transaxles) and is on the bottom of the pan so it gets every drop of oil out. There is also a 1/2 threaded hole that can be used for oil temp sender, and the kit comes with a plug if it isn't needed.
High temp RTV and ready to install.
