ChasingSand
- 785
In the last year I have been fighting many issues on my car and the last one I cannot figure out is why my brake pedal continues to go soft on me after bleeding.
I will bleed it in the garage then while duning it will become very soft and I have to pump it back up.
So far I have replaced the following. New Front Spindles/Brakes (calipers/Pads/Bearings/Brakes Lines, New Master Cylinder and In the Rear, new hubs, brakes (Calipers and Pads).
The old on the car: Turning Brakes (early 2000's and proportioning Valve)
What is strange is that when I pull the turning brake for the driver side it is firm, but the passenger side will firm up then the arm will continue to move.
Not sure if there is any correlation between the two?
