Turbo_Manx_Maniac
- 134
I have a 9" stage 2 clutch, 6 puck I bought from Outfront in my Manx, it had a CNC 5/8 Master and the normal CNC pulling slave. I've had the clutch fail (hydraulics) several times with no pedal, so I decided to replace it all after rebuilding the master & slave several times.
As CNC doesn't exist anymore, and I want new rather than rebuilding yet again, I decided to try the Jamar 5/8" master and slave. As I hoped, it all installed very easy. All the bolt holes and dimensions matched up to the CNC. The issue is that even though I matched the master size, the pedal is much harder that it was with the CNC. It feels more precise, meaning there is not much slop in feeling where it starts to pull, and this may just be due to being fresh fluid and bleeding. I noticed there is no master options for the slave, and there is no smaller master. This is gonna give me some leg pump, I do some rock climbing and grubbeling, and I work the clutch a lot.
Also, there is some dead pedal I can't get rid of, meaning I can't adjust the clutch to start at the beginning of pressing the clutch pedal. If I adjust the slave so there is a lot of tension on it, the old slave would start pulling it as soon as I touch the pedal, this one has an inch or so of travel before it does anything. If I lengthen the rod, it just pushes the pedal up higher in the resting position, the dead space is unchanged. The slave doesn't move in that first inch or so of travel. When I adjust the arm so the throwout bearing isn't quite touching, there is about 2-3 inches of travel before I feel the pull of the pressure plate.
Anyone else have this experience? Have any ideas to make it a little easier? Like a longer clutch arm at the transmission (091)?
