Dockmaster
- 827
I still don't understand why you can't simply plug the Moho into the trailer and charge through your trailer inverter? Your trailer inverter is only charging your trailer batteries if it is plugged into shore power or a generator. Otherwise your trailer batteries are only being charged from the solar panels via your charge controller direct to the batteries. If your trailer inverter is tripping when you plug in the Moho just reduce your charge rate on your Moho inverter as others suggested. But I doubt that the charging alone is what is tripping your trailer inverter. What else does your Moho inverter provide power to? A residential fridge? Some outlets, etc. ? I would try shutting everything off in the Moho and see if you can power the inverter in charge mode only.
I don't know what size your Magnum trailer inverter is. But if it is a 2,000 watt it should have more than enough to power a 125 amp charger in your Moho inverter. Your 15 amp trailer outlet at 120 volts A/C is equal to 165 amps of DC at 12 volts and would be 1,800 watts. So you have little reserve to power other items depending on your charge rate.
You can try to shut down the Moho and maybe charge while you are out riding and nobody's at camp?
