In Excess
- May 18, 2021
- 333
- 455
We have had a few failures the past 6 months with both our trailers. We serviced everything well enough we thought, we did drive to Missouri 3x this past year though. Point is check everything.
box trailer we had a caliper fall off and rub on the wheel, I guess this is pretty common, we were told to safety wire the bolts on. The major problem here was that the bolts are m11, not easy to find on road.
2nd was on our warrior we had a bearing cage fail after 17 years of use. Plenty of grease as the rollers were still there and stuck to everything. Unfortunately this took out the brake assy and our roadside repair meant replacing the axle when we got home.
I try to pull everything apart once a year but these were weird failures
