Which One Sand Tires Unlimited Sand Blaster Tires 33"
Reece Pettersen
Need to buy some paddles for my alumicraft 4 seat prerunner. It has a stock LS1 and S5. Never had a car with this little HP lol. Which 33" x 15 paddle should I run? Was thinking the STU-SB3315PRO/1. Will this motor pull the Pro2? Thanks!
I ran 33 #2's with an LS1/2D and it felt great.
The pro's have a more aggressive scoop.
I have always felt that the bigger paddle is best if you’re deciding between the two.  They do wear over time and get smaller.
You can always adjust air pressure to get more or less bite.
Think the pros will be too much bite?
I’d bet they would work good with that combo.
a buddy had a built up LS1 and he was running the pro 2’s and he liked them.
I like a little more wheel spin in my driving style. I’d think if it were too much traction for a stock LS1.... then add a cam and some heads, and that’ll fix it 🤪
The Pro #1 is the same size scoop as the the regular Blaster #2.
