- Thread starter
- #21
JM PRO
- 259
Did you purchase those cables from Kartek? Reason I ask is that I used an Identical cable from Kartek and had to change it out every season due to sand getting inside and making the throttle stick. I ended up using the gray cables from pacific customs and had much better luck.Shifter cables are done. Now the fun part of trying to sandwich in a fuel tank, heat exchanger and radiator into the car.
You are corrrect, those cables are from Kartek. What's interesting is this car had a grey push pull throttle cable fail afterless than 1 season last year. However the cable came directly from Control Cables in Santa Fe Spring. They replaced it but couldn't explain or diagnose the reason for the failure.Did you purchase those cables from Kartek? Reason I ask is that I used an Identical cable from Kartek and had to change it out every season due to sand getting inside and making the throttle stick. I ended up using the gray cables from pacific customs and had much better luck.
