Dustinp
- 31
I never had any problems with the frame. Only broke two stub axles and had a kennedy clutch blow apart. I loved that car.Good the hear. Any weak points with the chassie that should be reinforced?
AS with ANY CAR, the more you check and look at things the better off you will be! Keep those trailing arm bolts TIGHT!!! The main area on those chassis to keep eye on is the front lower arm tab to frame weld areaGood the hear. Any weak points with the chassie that should be reinforced?
