Jonesy
- Mar 4, 2023
- 46
- 7
Another new guy question. The CV joints with the most available angle is the 934, correct? Or will the 930’s be fine with the smaller price tag?
Welcome to the site. Axle angle and travel will depend on axle length. Shorter axle will have more angle than a longer axle with the same 14 inches of travel.Another new guy question. The CV joints with the most available angle is the 934, correct? Or will the 930’s be fine with the smaller price tag?
That makes sense. Just trying to do some research before I tackle this projectWelcome to the site. Axle angle and travel will depend on axle length. Shorter axle will have more angle than a longer axle with the same 14 inches of travel.
How much HP?
I have nothing currently. Just needing the angle with the project I’m doingWhat do you currently have . Converting 930 to 934 cv is costly . Cv bolts , stub shafts , cv , boots , trans flange , axles .
Yes, long travel. About 350 horseIf you aren't going long-travel....it doesn't matter that much.
How much HP?
Nothing yet. Picking up a bare frame Saturday. Using an S/C 3800 with the stock auto trans. About 300-325 hp. This car is a beam car that I’m wanting to convert to long travel. I’d say 1700 pounds or less on the weightIf you are currently running a 930s and not having any issues with them, stay with them unless you're ready to drop some coin.
to convert 930s to 934 you'll need
axles
cvs
boots
transaxle drive flanges
if micro stubs you'll need new stub axles or hubs depending on make
if midboards you'll need an entirely new hub assembly which will likely require trailing arm modifications or new trailing arms all together.
what kind of motor is in the car? hp, torque, vehicle weight, and tire size all dictate weather or not you should upgrade to a 934. although I have seen 500 hp v8 combos in lighter (2200) lb. cars get beat on with 930s and not have any issues.
Yes. Thinking 5x5 arms with the CV’s that will give the most angle. And absolutely on limit strapsSounds like you may be wanting to squeeze every available inch of travel out of your setup. If this is the case remember to use limit straps to stop the axel angle from exceeding the maximum angle when the car is airborne and allow for the eventual stretching of the straps making them longer over time.
I've never tried them but these guys are out of Australia and make custom joints that get 35 degrees. They look wider than standard cv joints so that would need to be taken inton considerationI have nothing currently. Just needing the angle with the project I’m doing
Most likely going to chat with the local machine shop and graph 930 CV’s to the trans CV axle tulips. Just brainstorming herefigure out how to use Parts off a sxs. lots of crashed shit out there for cheap. axles and cv's hold up well at crazy angles
I like thisAround the camp fire there are two style of duners,
1st style ( 930 guys always talking about axles and cv's that are broken or what to do so they dont break )
934 guys talk about how good the duning is, what is for dinner and where to dune next,
