Torque Specs for clutch & Flywheel
HTElectrical
May 6, 2021
247
90
What is the Torque on a  8" Stage 3 KEP pressure plate and the flywheel bolts?  Any loctite required?  Motor is a 2.5 Subi and trans MD4E.
Could be wrong, going on 4th season but I did mine at 55lbs for flywheel and 25-30lbs for pressure plate.
Both torqued down in a star pattern.
I spoke with kenndy recently and for the Pressure plate bolts it will depend on which ones you have.
10.9 Bolts=27 lbs
8.8 Bolts=18 lbs
Email from Kennedy 2007
For the clutch we recommend 25 ft lb for the 8.8 grade bolts or 30 ft lb for the 10.9 bolts.
The flywheel should be torque to 60 ft lb.  As long as you tighten the bolts immediately then use lock tight but if you do not tighter right away it will give you a false torque reading.  So normally we do not recommend it.
KENNEDY ENGINEERED PRODUCTS                   661-272-1147
38830 17th St. E                                                Fax: 661-272-1575
Palmdale, CA 93550
10.9 Bolts=27 lbs
8.8 Bolts=18 lbs
Kennedy 8mm 1.25 Thread 20mm Long Clutch Bolt And Washer Grade 10.9
So I guess it is 27 ft. Lbs
And, do you wipe a bogger on it, use locktite (which color) or nothing???
