Jonesy
- Mar 4, 2023
- 46
- 7
Anyone know where a guy can find a tutorial or some coaching on how to convert a beam car front to an “L” arm style long travel? Not asking for handouts. Just some tips/tricks or how to’s… Thanks in advance
Are you looking for something like this? I built this for my car probably 10 years ago. It worked very good. I used the standard combo spindles from Pacific Customs. But it can be changed to work with any spindle. I can probably find the cut files for them depending on what you are going to use for spindles and steering rack.Anyone know where a guy can find a tutorial or some coaching on how to convert a beam car front to an “L” arm style long travel? Not asking for handouts. Just some tips/tricks or how to’s… Thanks in advance
Yes sir! Or the style that connects to the b columnAre you looking for something like this? I built this for my car probably 10 years ago. It worked very good. I used the standard combo spindles from Pacific Customs. But it can be changed to work with any spindle. I can probably find the cut files for them depending on what you are going to use for spindles and steering rack.
This is the only style I have. I guess you could use just 1 of the bulkheads and build the arms to suit your chassis. I like the way this suspension rides much better.Yes sir! Or the style that connects to the b column
Biggest bummer there is clearance for larger tires and compromised steering angle.Yes sir! Or the style that connects to the b column
I’d be interested in more infoI had on the old site a full build process,
If you are doing a leading edge car,
I have some buggy works arms you can have,
you will need the Spindles, latest rage sells them or like like @Kraut_n_Rice said Tabzone,
I did the Tabzone front bulk head,
or you can use Send Cut Send,
Not sure if they are available? Website was updated last in 2023. However, I do have a contact email sent to them.There are kits available. I think it was TabZone that had one, but I don't see it as a kit now. Just individual parts.
A Arm Kit-Dual Shock | nicholsfab2
This center mounted a-arm kit, can be a great up-grade from your stock VW beam suspention. Designed to graft on to your stock pan, it can be installed on Baja bug, Manx, or sand rail. Ships rawwww.nicholsfab.net
Yes! If I could find a complete “kit,” would be perfectAre you looking for something like this? I built this for my car probably 10 years ago. It worked very good. I used the standard combo spindles from Pacific Customs. But it can be changed to work with any spindle. I can probably find the cut files for them depending on what you are going to use for spindles and steering rack.
Inquire with Joel Garside on instagram. He has a complete J-arm kit he sells and can hook you up with hubs too. I forget how much the kit is but I remember it’s pretty cost effective. Wilkey put it on his latest Baja bug build.Yes! If I could find a complete “kit,” would be perfect
Do you have a link to him on IG? I’ve searched a few but, nothing much came upInquire with Joel Garside on instagram. He has a complete J-arm kit he sells and can hook you up with hubs too. I forget how much the kit is but I remember it’s pretty cost effective. Wilkey put it on his latest Baja bug build.
Disregard. I think I found him. Thanks againInquire with Joel Garside on instagram. He has a complete J-arm kit he sells and can hook you up with hubs too. I forget how much the kit is but I remember it’s pretty cost effective. Wilkey put it on his latest Baja bug build.
