Gear one cv seal kit
Markcsand
Anyone using these?
Anyone using these?
Yep. I use them on my car and have installed them on 3 customers cars.
Parkers new midboard hub design come with them already on the hub.
I have a had great luck with Tatum’s which look the same . 1776813243236.jpeg
I had some with rubber and they just got eaten up. Can't remember the brand.
Have you opened them up to see if the seal is still there?
I have them on my car and they work great!! The rubber ones I believe were AGM and think they stopped making them but not sure.
Do you mean on the trans or the hub?
If trans, yes, I have run them for 3 seasons and seal is still there.
Customer is bringing me his Funco in a week or so and I will look at the seal on the hub when I install CV savers on the trans side.
I tried those initially and did not work well. The rubber just disintegrated over time.
I'm putting new CV's in right now so I ordered a set from Gear one. I guess I'll find out how the leather ones work.
So just the transmission side? I don’t see how they would bolt up to the midboard
Leather CV seals FTW!
I believe AGM were the first to do there rubber cv saver. We used them and notice room for improvement. With the help of Kevin mcmullen we came up with the leather Cv seal. While its not a perfect seal on the axle shaft they are way more durable and due to the centrifugal force of the cv the leather does a fantastic job keeping the grease in the joint.
Thanks for taking care of my order! Fast service. Carl with the Elite Car.
