Building a new trailer. What are your must haves?
If your doing a water tank, add a sink. Old trailer didn't have one, new to me trailer did. Never thought much about it until I had one. Use it multiple times a day. Keeps the wife happy not going into the motor home to wash up especially after working on cv's.
I'm having aluminum fuel tanks with a steel skid plate made for my universal. The rust in the fuel from the steel tanks bothers me. Make sure he mounts your jack far enough back that you can open your tailgate (if you happen to tow it with your truck), mine is not, and it's frustrating. I had him mount my 2 spares under the last trailer. The solar panel to keep the trailer charged is a great idea. On my next one, I'm going to have him install stronger tie-down spots on the side (the ones he puts on there are questionable). Ramping the wheel wells and making them match the track width of my car. Currently have one wheel on and one wheel off, so the car is always more on one side. I had him put scissors jacks on the back of my last one (you can load if not connected). I also always do my fuel on the non-camp side. I like to keep the camp side clear & I keep my generator on that side. Next trailer, I'll probably do a fuel reel in the front so you can fuel from either side.
Aluminum tanks isn't a bad idea. On any of my other trailers I've never had a rust in the fuel issue but god I would not want that to happen. Mine is a V Nose so not sure how far back he can mount the jack and I won't be doing much if any truck towing because its going to be very heavy. I'm really liking the idea of mounting spare under the trailer, I think I'll have him do that. I think he actually welded in the tie down points on mine but I will double check those. I'm not doing drive over wheel wells. I built the trailer as wide as possible and I think I have 90" between the wheel wells which is more than enough for any of our cars, We don't even have to strap the front ends at 90". Scissor jacks aren't a bad idea but the trailer is so heavy and with the spread axles having the last axle so far back I don't think that would be an issue for loading not connected? Even on my last 2 stackers I could load and unload not connected. I'm usually against the road so i don't have an option to have my camp side clear but thats why I did the fuel reel, I can fuel both sides easily if needed
