Sand Car Prep, Restoration, fab work in AZ.
mc22
Hello GD members, My son and I have been doing quite a bit of side work over the last several years we are thinking we might turn this into something!
For a little background, I was an heavy equipment tech for 20 plus years, specializing in wiring and heavy diesel engines, I now manage a large fleet for a company. My son has been tied to a Tig welder since he was 14, and has been a welder/fabricator for a well known SXS shop for the last 3 years doing all the tig and mig welded products they offer. We don't plan to quit our day jobs yet but I figured id start here and introduce MCfactory.
If you are in the East Mesa or AJ area and need some work we can:
Wiring repair, either old school relay, toggle or complete modern re-wire and everything in between.
Fabrication/welding repair
Cad Design Plasma table capability
Full car updates summer refresh
Radius cage
Simple maintenance, Inspection and Prep
Custom exhaust
Small part powder coat and cerakote can sub large chassis PC
We can do simple panel work, dash panels. We are not ready for full 3d body work. but we will get tooled up for that as we grow.
ETC...
PM Here, Email or call 480-819-6122
Here are some photos from the last couple months.
Pie cut Stainless exhaust
Full car re-model over summer. stripped down, added intrusion bars, updated front bumper, went from a 091 to a 2d and we rebuilt chassis from B-pillar back, all Tig. car had a nice out front 2.5 engine and nice engine harness, rest of the car was a basket case and got a complete re-wire, new dash/gauges. re-located battery, added master switch, put ECM and engine relays in a vented box.
That is some great looking work. I’ll make sure to pass your information around if they are looking for someone to do work.
I know you said you aren’t ready for 3-D body panels, but how about hoods, or flat body panels?
Thanks! Flat panels we can do, we have a 5ft sheer and bead roller. we can probably pull off a hood and may make a deal on the first one since we'd be learning.
Best of luck to you. Its great to see more guys providing service. You should do a write up of all the parts you used to swap the LS and parts you used on the LS. What is the electronic box mounted behind the radiator on the drivers side?
Thanks EastMT, I believe you and I traded some trans parts a few years back and had some good calls on Honda parts or suspension. the little box on below the radiator is a Pro-Taper hour meter, this is made for dirt bikes and uses vibration to clock actual run hours, these are pretty inexpensive and its within 2 tenths of my Holley ECM run time. its a pretty cool tool for maintenance.
Like that electrical box. I did a set up like that for a friend to put the ecu fuses and relays In to keep out of the sand.did same for mine as well.
Later on he got carried away and had major mods done they put the relays under the seat with no solid floor with a seat that took a long time to get out. A shock when he told me he had a couple relays go out. 🙈 and car never ran right after mods either.
I've had good luck with the pelican style boxes from Harbor Freight. you do need to put some vent holes in them as the relays do get warm. My car has a separate panel under the seat that is easily un screwed from the bottom of the car, it hinges down and is easy to get to if there was ever an issue.
