ChasingSand
- 964
Currently using an Airraid filter but after this last trip (5 days) it’s collapsing in a couple of areas. Anyone have luck with a different brand?
Where did you buy them from? I found one I want but I don’t see it for sale online anywhere.I have OTR filters on my car, they seem to work well and are easy to clean.
Yep. If you replace every season, not terrible. Beyond that, dusty intakes.R2C were tried and discussed a long time ago.
If I remember right, the consensus was not good and let sand thru.
Donaldson, built for turbos in heavy dust.
Donaldson Air Cleaner- B080080
Brand - Cycloflow Family XRB Primary Application - VERMEER 163670065 Rated Flow HR - 360.21 CFM Rated Flow LR - 261.33 CFM Rated Flow MR - 314.3 CFM Restriction HR - 10 MM H2O Restriction LR - 5.98 MM H2O Restriction MR - 7.99 MM H2OFilter Cross Reference:REPLACED BY-B080074 ; SWARAJ...www.dieselequipmentinc.com
Rated for ~350whp each. I got 4 seasons out of a $40 filter. No restriction, no dust, just figured it was time.
If that Donaldson is the one I think it is then it has the provision for an inner filter element also. So, you can maintain the outer/main filter element by blowing it out with air and not have to worry about damaging it. Also, you can put a debris filter on the inlet of that housing.
