Cookie
- 2,347
I know without going on a dyno, it is hard to know the fuel pressure under load, but I have a basic question. So here is the situation.
Subaru 2.5 turbo motor (450hp), just got back from shop and dyno (not at Outfront). Cart was not even drivable. Motor runs bad, we check plugs, wires, all new Fuel filters as well. Engine seems to sputter, pull a plug wire and it won't idle on 3 cylinders.
So we pull off my Engine Fuel pressure gauge and put on the Subie. At idle it is at 45lbs, to me that seems very low. We increase the fuel pressure to 65lbs at idle, now it runs and idles smoothly. We were able to run it all weekend, but I still think that is low, it still has a sputter when you first hit the gas but clears out and runs. I think my turbo Honda at idle is more at 80lbs, will confirm when I get new gauge. What do you think it should be at idle?
Another question, engine builder said it was good to go after a $1200 dyno tune, but it came out of the trailer running like crap. What would cause a recent drop in Fuel pressure? Before all of this, all E85 was removed from tank and all new Fuel filters were installed as well.
