Reece Pettersen
- May 6, 2021
- 331
- 434
My father bought Glamis Mike's old car as a project and is now posting it for sale after putting some time into getting it dune ready. Car will be in Gordon's Well December 27th through 2nd, if anyone wants to see it. Please let me know if you have any questions.
Price: $55k
November 2025 SERVICE AND REPAIRS
1. Headers taken to Tom Face (Scotty’s Mufflers) for rebuild and repairs, Black ceramic coated
2. Oil bypass adaptor O-ring replaced #3799N75 and resealed
3. Drained oil and replaced Filter Wix 51515R with Valvoline VR1 20-50wt full synthetic
4. Removed the battery and replace the battery/Optima 34/78
5. Repair the oil leaks from the block for the oil pressure sensor fittings replaced
6. Serviced the Fortin mid board floating hubs, new seals outside and inside Bearings inspected and greased with Maxima bearing grease
7. Serviced the 934 CV’s polished and inspected, cleaned and repacked with Belray and Swepco grease combination, axles inspected and polished
8. Replaced radiator cap Stant 21-25lbs
9. Replaced the roof headliner new vynal
10. Wired in a dome light
11. Fuel filter Wix #33008, cleaned primary filter, replaced the fuel line
12. Replaced the braided brake lines since they were too long and brakes didn’t work, new hard lines and fittings and added 2lbs residual valve, Motul 600 brake fluid
13. New clutch hard line flushed Dot 3 brake fluid
14. New air filter OTR C010525 and pre-filter OTR FGA35
15. Charged the shocks with nitrogen shocks 150lbs, bypass 175lbs
16. Front hubs bearing greased
17. Replaced broken springs on Dzuz tabs
18. Trans fluid inspected and changed and replaced with Lat 85-140wt 4 quarts
Price: $55k
- 3.2l Turbo Acura massive intercooler
- Motec computer with race harness and wiring
- 5-Speed MD5 with Deco Case
- 934 Fortin Midboard Floater Hubs
- Howe Power Steering
- 2" hollows
- Fox bypass on all fours
- Suspension setup by Bill Varnes @ Mirage
- PCI Intercom & Kenwood Radio
- Lowrance GPS
- Fuel Cell
- DWT wheels with OMF rings
