Realbadlarry
- 3,608
My Brother in law has an old school rail, 1835, swing axle, johnny's frame....are they worth anything anymore?
Think the probem is with a vw yes simple easy and can be built reliable but parts are damn expensive to build a good one.My 2275 got good parts and thos alone were almost 4k 15 years ago im talking complete sump to air filters.I ended up doing j 35 swap for about 2800 1500 for engine ecu and harness.Needed to buy radiator,fuel system and headers and had an engine that had more power and just needs oil changes blow it up get another for a 4-7 hundredThere are people that use them and the new stuff isn't really any faster. But, it rides a whole lot rougher than the new stuff.
When I see a group running the dunes and there is a VW in it....the VW just putts along and has no problem keeping up. Yes, V-6s and V-8s are blindingly fast, but sane people can only dune so fast.
What sort of terrain do you run?
The main thing, that I see, wrong w/it is that it has a V-Dub motor in it. There are lots of good/better motors that would fit. Personally, I like older motors that run a conventional distributor and a carburetor. If somebody was building a rail today, they aren't spending $10k-$50k, or more, and putting a motor descended from the 30s in it.
But, to answer your question....it has great worth as a useable machine. You could put $1,000 into it a year, and it would still be way cheaper than a $20K machine.....much less what today's machines cost. If you want to sell it, it is worth $1k-$5K.....assuming that it runs. If it doesn't run, $500-$1,000, and it might be hard to sell.
Hit up Conrad Nelson on his FB page. He's an old school aficionado and will be able to answer all your questions.My Brother in law has an old school rail, 1835, swing axle, johnny's frame....are they worth anything anymore?
I broke out even with selling mine. End up selling at the low points and buying high lol.I've helped many guys swap from VW to Honda. Many of them actually ended up with money in their pocket after selling the VW.
Yeah. Good ACVW shit is getting rare, prices are up.I broke out even with selling mine. End up selling at the low points and buying high lol.
But this time I got the Honda for cheaper than planned so it worked out. But now I’m ahead.
Meah, I just let a little air out of the tires…Old school buggy requires some thinking. When you adapt a VW
running gear the a buggy, think of the weight you just removed.
Early builders would "Cut" the torsion bars to ease the bounce.
I chose another way. I cut the tubes and rotated them "Opposite"
to cause the front to ride smooth over the bumps. Hitting the bump
pushed the wheels up, and the "Cut Tube" pushed back. Resulting
in a smoother ride than just a weak front end.
(That's your trivia for today)
Chop actually isn’t an issue. Long sections of big whoops at speed are where the beam/trailing arm just runs out of travel. Everything is great and smooth… Until it very suddenly isn’t. I just don’t bother if there’s a long section. It’s like 0.2% of our dune miles, so doesn’t matter much.I grew up in a beam car with an 1835..
I couldn’t even imagine driving across the chop in our camp circle in that thing.. my back hurts just thinking about it. lol
Granted ours was a dirt car and was not a sand car.
