ChasingSand
- 1,049
Been chasing an issue for the last month. I recently went from relays for my fuel pump and fans to the MSD solid state relay.
I was using the ECU for the ground trigger for the fuel pump. Issue I am having is, anytime power is applied to the ecu it’s triggering the pump. I have checked my wiring 4X and also sent the ecu to diagnostic and they claimed it’s working as it should. I decided to try and wire in a standard relay instead of the MSD and the fuel pump worked as intended.
I undid the trigger wire and put it back on the MSD and the pump continued to run.
I tried two separate ports on the MSD with the same results.
Anyone experience this?
