Trailering tires
jmp
Where do you get them? I am referring to the skinny pizza cutters to get a friends funco in his 94" wide opening enclosed trailer. I have a pair that came with my black widow when I bought it but they were a custom deal. I saw Guni wheels has options for real small diameter tires. Are there any other options?
Guni wheels are expensive. You can get an inexpensive pair of Empi wheels and put some cheap tires on them for way less. Even used tires are fine. If needed, call Grant and find out what he gets. I got mine from Funco with my new car and that's what they gave me.
Stock vw wheels are an option as well. As long as the clear the brake calipers.
I have a set of stock vw wheels and a set of some skinny traction tires that look like what a 1600 car would run.
  • Like
Reactions: jmp
JY for something like this:
And drill the wide-5 pattern into the flat face? Keep the anchor bolt and cap as a centering tool. :)
Buddy of mine used some old harley motorcycle style front wheels. Cut out all the spokes and welded on a plate with multiple lug patterns that he plasma cut. Worked awesome.
I would sell my trailer and buy a new one, I hate changing tires and then storing the paddles.
Any photos? I am looking to do something like this since I need 17" to clear my calipers.
I just use regular old VW steel wheels with the smallest size tire I could find to fit it
Latest rage had some real skinny wheels that my buddy used with small passenger car tires
Sorry Reece, it was years ago. I dont have any photos.
Essentially it was a wheel like this. He cut out/removed the spokes and welded on a flat round plate into the barrel of the wheel on the outer most edge so the car would be as narrow as possible. he owned a plasma table so he just made a center bore cutout for the hub and cut out the lug pattern needed.
