Antigravity battery or any other lithium variant
Jtmoney714
Who all runs these types of battery’s in their sand car or sxs? Worth the price? Any issues to look out for?
I run the atx 20 hd and its worked great for me fires up the Ls better than the odyssey i had in the car previously I however do not run a big stereo system or leave the lights on when I'm stopped so i cant comment as to how long they last without the car running.
Nice thing about good lithium like AG is there’s built in protection, so if you did leave something on, it’s usually not junk.
We prep a lot of cars,
My car has a Optima, starting to feel that is the worst battery on the market, I just put one in my car a week ago and it was around 10 volts after a week of sitting, every time we get a new Optima it gets worse, we went to a Total Power Racing Batteries have been amazing for us,
We also have changed out so many Odyssey Batteries, no one has really lasted for a year with the same power it started off with.
The Total Power we installed last night on a Funco, i ran the compressor on an off from 0-170Psi 3 time, and the voltage did not even change 0.2 of a volt was amazing,
Pulling my Optima after Halloween.
Look into li time, Power Queen, redodo, and watt cycle for their hybrid starting lithium batteries. They all have great battery management systems, some with Bluetooth.
I have four 100ah Power Queen batteries and I absolutely love them. They are a game changer. Unlike acid batteries, you can use the full battery, it doesn't drop below 12 volts until it's dead.
Modern Optima batteries are the biggest POS made.
My car came with a Full Throttle battery in it. I expected it to be bad by now not knowing how old it actually is, but after two years, it is still cranking along. I do keep it on a tender though so I'm sure that helps.
I run (2) Full Throttle 410 Batteries in the new rail and so far, seem good. I went with (2) Li Time 100Ah Lithium's for the new IROK with BT and after some setup challenges they are working well. Customer support was very responsive and nice to see.
The Anti Gravity batteries have a nice feature in their BMS. If the battery is dead you can push a button and it will give you one more start. Don’t forget that you will need a different battery charger with lithium.
I had a shorted diode in my alternator, and have forgotten to turn the ignition off a couple of times. Killed my Total Power to absolutely nothing 3 times, 4 years old and still cranking strong.
I hope Antigravity has improved their stuff. We sold a bunch of their jump packs, when they first came out, and they had a very high failure rate.
I have a couple of cars we are prepping, and the optima mount is welded in
Anyone use the XS batteries, they have a group 34, and the specs seem a lot higher than the Full throttle,
