Speed UTV
800K.:ROFLMAO: And he brings it into the SSSS on a forklift... What a fucking joke!!! After all the bullshit with the speed cars, now he is going to try this.
Does anyone know if he has any pre orders?
Who fucking cares??
IF anyone was STOOPID enough to give that clown a dime, they deserve whatever they get in return!
the first problem i see is that drive shaft slip joints don't like to plunge under load remember the extreme driveshaft axels its going to snap the transfer case in half
Pivot and transfer case output should be in the same-ish spot to reduce plunge. Not super different than a trophy truck that sees (very little) plunge under load. There’s 2 of them to share load, plus another reduction box on the arm, so they’d see less than half of what a normal driveshaft sees.
Extreme axles saw multiplied engine torque since they were on the tire. Biggest thing with those was they’re not CV, so any difference in angle between the yokes causes lots of issues that have to go somewhere. Semi trailing arm naturally sees camber change throughout travel, so you’re seeing plunge and U-joint phasing problems at the same time.
I do see a problem with the design related to the drive shaft:
Based on how it's drawn, the transfer case output connections are not in plane with the driveshafts. This means he'll need a CV there. A double-cardan unit will need less maintenance, but will be limited to 30* of maximum combined angle. There's already significant gangster lean from above, so this may be an issue. Other alternative would be a Rzeppa type like the rest of the car has, but those require more maintenance and CVs haven't been a strong suit of this car already.
Had he gone multi-link and had trackwidth change, the CV angle issue would be reduced... :ROFLMAO:
Typical Speed fashion at SSSS apparently there were Chinese investors in town with the apparent owner of Speed “Joanna Li”. The video released a week or so before SSSS claiming 15 cars a DAY being delivered along with a lot of other BS was to try and get more money. The “V8 UTV” was hauled out on a forklift because it apparently wouldn’t eve roll. Looks like all smoke and mirrors again to get money. Maybe the container was seized with the finished V8 car like the other 35 containers HSI seized from Speed awhile back.
His Chinese Girlfriend Joanna Li who got the $$ loan from the CCP (Chinese Communist Party) to build the speed UTV?
.... allegedly....
.... allegedly....
He was also... allegedly... buying a house in China and they are... allegedly... having a baby. I'd wager to bet that his Pullout game is very weak.
Either way, he's a fucking sellout and her panty drawer probably smells like the entrance to Harbor Freight.
Chop-Chop
Hey! I had nuthin to do with it!
Shrimp-fried rice?
Why you have to ruin the entrance to Harbor Freight? LMAO!!!! I will never walk into that store without laughing.
