Crusty
- Apr 29, 2021
- 6,116
- 6,538
What's the best method to remove about a near cup of sludge (gum, varnish, muck) in an ATV Gas Tank? Quad was ran dry, but this stuff collected at the very bottom by the petcock fuel intakes inside the tank. Plastic tank, so inside is otherwise clean, no rust.
Seafoam good enough to get that crap out by running it or go the route of remove tank and do the vinegar/water, etc. treatment?
I'm guessing the fuel lines and carb will have some of the same sitting in them and will need same or the seafoam should be good enough to get it going, run it clean?
thanks,
thanks,
