Camacho
- May 22, 2023
- 21
- 3
On a h pattern dog box can u pre load the shifter for the next shift and shift clutch less like u can on a sequential ?
The issue is that the dogs can round the edges, when this happens, it does not hold a gear,On a h pattern dog box can u pre load the shifter for the next shift and shift clutch less like u can on a sequential ?
Street car trans modified to dogs by liberty .which brand of trans
If it's a dog box, you should be able to.
Doesn't mean you should. It's still better to use the clutch.
Just wondered if the different mechanism of the 2 types would play a role in preloading before a shift . I guess a sequential would be called a wratchet ?If it's a dog box, you should be able to.
Yeah, it's usually shift forks just like in a synchromesh. They just replace the synchro cones with dog engagement teeth. Same process to operate: lift, shift (or throttle cut with a strain sensor). Just pull back a bit, chop the throttle, slam it into the next gear like it owes you money, and motor on.Just wondered if the different mechanism of the 2 types would play a role in preloading before a shift . I guess a sequential would be called a wratchet ?
Dont think they use a drum ?
I am all for using a clutch on a h .
Just curious. Been using no clutch on my mendi 7 years , no problems.
